Keithley sourcemeter resets itself out of 4 wire voltage sense back to 2 wire sense when performing a measurement
Hi Ben,
forget the stars - I am old enough that I do not need these things.... - but it might be that "Proven Enthusiastic Veterans" and/or "LabVIEW Champions" need it ???
I think the code works as expected - but where is your email-addr. ? - send it pls. to me @ web.de
In addition I have a very "handy" thing for you - have a look to attached pic. - since last week I have an
"integrated garden fork" in my left wrist - thatswhy I sit at home and have time for reading this forum.
Inline-skating can cause problems............. - but ......... no risk - no fun !!!
Regards
Werner
Message 11 of 17
(1,137 Views)
HI Werner,
I just sent my second request to the e-mail you gave in your first reply.
Incase you do not get the request, my e-mail is
bar@dsautomation.com
And once again let me thank you!
Ben
Message 12 of 17
(1,128 Views)
And thank you for specifying that was a skating accident.
I wear carpal tunnel braces on both hands and at first glance I thought you may have being doing too much "un-protected wiring".
Ben
Message 13 of 17
(1,126 Views)
Did Keithley get back to you?
Ben
Message 14 of 17
(1,096 Views)
Yes they did.  The driver does support setting the instrument into 4 wire sense (via one of those esoteric commands that are hidden in the structure),  but the instrument still reset itself to two wire mode.  Indeed, it does some quite unexpected things one 4 wire has been invoked.
Keithley are having another look at the issue.  They have said that there is a problem with the driver.  I'll keep you posted.
Dave
Message 15 of 17
(1,088 Views)
Hi Dave,
one more idea - maybe  a workaround........ on order to set the SMU into 4-wire-sense-mode.
The K2400-SMU is set into 4-wire-mode by  GPIB command      :SYST:RSEN ON;
and back to 2-wire-mode by    :SYST:RSEN OFF;    try to send the command above in front of
the sub.vi, where you want to measure the Voltage ( via VISA - GPIB - write ).
Find as attachment Frontpanels and Diagrams dropped into EXCEL-File, how I have tested
Accumulators for one of my colleagues, who needs to know if this accu is still o.k. for use
during long time flight with a glider and recording Position-Data from GPS-System.
If you want to test these vi's --- let me know.
Werner
Message 16 of 17
(1,075 Views)
sorry - I forgot the attachment .............
here again!
Message 17 of 17
(1,063 Views)
