Kernel and convolution
I need to apply a 3x3 kernel to an 8x8 matrix of arrays. I'm pretty sure I need to use the convolution VI but so far I haven't managed to make it work.
Any Ideas?
Cycy
(4,107 Views)
Hi Cycy,
There is a good example on doing convolution by searching for "convolution" in the NI Example Finder in LV 8.0 or higher.  It's called "Edge Detection with 2D Convolution.vi". Basically, you would just have to enter the 2-D arrays (8x8 matrix and the 3x3 kernel) into the X and Y inputs of the Convolution VI (it doesn't matter which input is used for which 2-D array). The output will be a 2-D convoluted array.
Let me know if you still have any problems or questions.
Regards
Way S.
NI UK Applications Engineer
(4,089 Views)
