Key F4 to retry the last function / instruction similarly in MS-Office
Key F4 to retry the last function / instruction similarly in MS-Office ?
(2,657 Views)
Hi WerBoh,
use a key press event to detect F4, then restart the last function used in your application. QueuedMessageHandler might be a suitable programming scheme...
Or do you talk about the LabVIEW IDE?
(2,654 Views)
Your question isn't very clear on what you are trying to achieve.
I'm assuming that you're talking about capturing a user pressing the F4 button in your LabVIEW application to retry the last action/command. I think this would be possible using an event structure to detect the F4 key being pressed and using this to prompt your application to do that action/command again.
The event structure can be set up as follows:
How you actually implement this will depend on the architecture of your application - you'll need to remember the last action that was performed (perhaps on a shift register).
If you're talking about in the LabVIEW development environment itself - I don't think this is possible. You could suggest it on the LabVIEW ideas exchange though!
(blog)
(2,652 Views)
