Key Navigation and pop-up controls
I would like to put numerical/string controls on key so that when the key is struck, the control becomes visible and also key focused. When struck again, it disappears. Is that possible? I have figured out how to do it with two controls (one Boolean on the desired function key that controls the visibility, and the numerical/string control itself). For the sake of simplicity, however, it would be much nicer to have the number/string control do this all by itself without the extra Boolean. Also, is it possible to have these numerical/string controls appear in their own small window upon hitting the function key?
Thank you.
(3,057 Views)
You Need to get the lvwutil from ni.com, it contains keystroke capturing
vi's that will allow you to do what you want programmatically.
"uc_greg" wrote in message
news:506500000008000000FA4C0000-1023576873000@exchange.ni.com...
> key?
> Thank you.
(3,057 Views)
What version of LabVIEW are you using? Version 6.1 has an Event Structure and you could easily implement what you want with the Key Down event.
(3,057 Views)
UNfortunantely the version is 6i, not 6.1. I checked this version thoroughly and it makes no reference to "Event Structuring". thanks anyway.
(3,057 Views)
