Key Navigation
I have one main VI called Header_Footer.VI and some 4 vis. The Header Footer VI will always Run and depends upon the boolean control clicked on the Header_Footer VI, the corresponding VI will run and it placed at the cente of Header Footer VI.I assigned a control key navigation as F2 in Header_Footer VI. if the user clicks on the middle vi the Keynavigation is not working, eventhough the Header_Footer VI is running because of lost focus. How i can pass the Key navigation to the Header_Footer VI.
(2,914 Views)
Another way is to track the keyboard strokes utilizing the keyboard.llb vi's. Attached is a zip file that contains these vi's. You can track any keystroke or combinations of keystrokes from any program or window. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,914 Views)
