Keyboard input to separate Win. application without pressing key
How can I run (communicate via keyboard) windows application for programming microcontrollers from LabView? I mean “pressing” Ctrl+P for starting programming with LabView without human action.
Message 1 of 9
(5,982 Views)
I've linked an example program here that contains a subVI which simulates keyboard input. You could use it to simulate key strokes, but you would need to do something like an Alt+Tab in order to change key focus to another window. Honestly, controlling the application this way will be tedious and the unpredictability of window tabbing order could present problems. Does this application have an ActiveX (COM) interface? If so, I would recommend using ActiveX in LabVIEW to control the application.
Kind Regards,
E. Sulzer
Message 2 of 9
(5,960 Views)
At home, I have program Girder http://www.promixis.com/products.php?section=girder, they don't need to change key focus to send keystroke to any running application.
Message 3 of 9
(5,954 Views)
How about this?
___________________
Try to take over the world!
Message 4 of 9
(5,950 Views)
Problem is how to simulate any keystroke in some open Windows application from LabView application
Message 5 of 9
(5,945 Views)
@AESulzer
In Virtual key constant there is no Alt key to enter Alt+Tab.
Message Edited by Oldi on 10-14-2005 07:19 AM
Message 6 of 9
(5,944 Views)
The G toolbox from George Zou has a tool that can do the job. I don't know how it will behave with hot keys that are used by the operating system, though.
Message 7 of 9
(5,929 Views)
Oldi,
In the example I directed you to, the virtual key "MENU" is equivalent to the Alt key.
E. Sulzer
Message 8 of 9
(5,910 Views)
With combination of Find Winodows.vi and Set Active Window.vi Demo from G Toolbox
and Emulate Keyboard.vi from copytext.zip I get a working VI, but it doesn't work if target application is in a Taskbar. If Application is only inactive, then everything is OK. Good enough.
Message Edited by Oldi on 01-04-2006 07:21 AM
Message 9 of 9
(5,790 Views)
