Keyboard interfacing in starter kit 2.0 Robot
Hello
                 I want to control starter kit 2.0 robot using  keyboad . anyone  worked  in Keyboard interfacing in starter kit 2.0 Robot ?
                 I use event structure to get  scan code of press key . according  to this code control robot  example if forward key press then make steering frame velocity array [0,1,0] (1 m/s forward velocity )  sand give to "Apply velocity to Motor" VI . so robot move according to steering frame velocity.
but this logic not working  !!!!!
can anyone help me ..?? 🙂
Nirav Virpara
(3,073 Views)
Hey,
The robotics starter Kit is a standalone machine with an FPGA on it. The Starter Kit is not controlled by a computer. However you could instal drivers for a Keyboard on the FPGA , then write a code so that the FPGA understands the keyboard input and be able to control your robot.
(3,036 Views)
