Keysight/Aligent U2001H Sensor Triggering
I am new to Labview and to using these power sensors. I am hoping to trigger the sensor either internally or externally to match the signal being measured. I am essentially using the following VI changing run mode to normal for internal triggering. However, when I change the trigger to internal I get an error saying "-221 settings conflict" and when I try to trigger externally (using a 2V pulse signal with a period of 10 ms) the signal 'sticks' and does not update.
If anyone has any advice it would be appreciated! Thanks
Message 1 of 1
(1,029 Views)
