Kiehley 2701 Ethernet Not Appearing in Labview
I'm quite new to using Labview so perhaps I am overlooking something, but I cannot seem to get my Kiethley 2701 to appear in NIMAX. I manually configured the IP address as the manual mentioned and can even ping the device in the command prompt. However, when I try to search for the device in NIMAX or VISA I cannot see it.
(823 Views)
Try the steps in Ethernet Instrument Control Tutorial
https://tmesystems.net/
(787 Views)
Thanks for the reply, the device still doesn't appear when I get to add a TCP/IP resource (step 4). Trying to find which port to use for the manual socket option but I don't think I can determine. Has anyone encountered this problem before?
(745 Views)
