Kinect with labview
HI,
       I have to interface Kinect Xbox 360 with LabVIEW 2012.For this I have followed all instructions given in the below link.
 https://labviewhacker.com/doku.php?id=projects:lv_kinect_interface:lv_kinect_interface.
       I have also instal Kinecthesia Toolkit for Microsoft Kinect.
       Now when I open the Kinect example. vi , it is showing the following error:error kinect exmaple.png
 Please suggest me possible solutions regarding the issue.
Thanks and Regards.
Shreya
Message 11 of 14
(1,316 Views)
Shreya,
This sort of error normally occurs when there is a pathing issue with the examples - essentially, LabVIEW knows that there is an example but cannot locate it.
1. Have you tried reinstalling the Kinect Toolkit?
2. Has the example worked prior?
Jae
Message 12 of 14
(1,285 Views)
          I tried uninstall and then reinstall Toolkit ,  also tried uninstall and  reinstall .net framework 4.0 and Kinect SDK v1.5. But again it is showing same error.
         Pleas suggest me fruitful solutions.
Thanks and Regards.
Shreya
Message 13 of 14
(1,270 Views)
Hi Shreya111,
Have you correctly directed LabVIEW to the filepath where the library is saved?
Additionally, the link below has troubleshooting steps for using the Kinect 360 with LabVIEW and also discusses the functionality more in depth. It may be helpful in your application.
https://forums.ni.com/t5/Example-Code/Kinect-LabVIEW-Interface-Using-Microsoft-Kinect-API/ta-p/39961...
Hope that you have a nice day!
Carli S.
Troubleshooting & Maintenance Digital Business Manager - NI
Message 14 of 14
(1,239 Views)
