Kinesis TDC001 .NET container showing empty controls
I am trying to automate TDC 001 DC motor by Thorlabs using LabView, however after inserting the .NET container and linking the .dll , I am getting a blank control in the front panel.
Also , even after connecting the DC motor to my computer via USB , while running the the VI, it says ' Device not found ' .
As mentioned by the kinesis manual , i have copied all the necessary .dll in the same folder as the Project of this VI.
Please help me out.
Sandhya
(2,446 Views)
Sorry for that  this is not a solution.
I have the same problem with you.
Even though I connect controller to my computer, LabVIEW doesn't find any device.
If you resolve this problem, can you give me some advice?
(1,702 Views)
