Kintex-7 Xilinx Coregen Support
Can someone tell me when or if the the new 7975 FlexRIO board using a Kintex-7 FPGA will support Xilinx Coregen IP?
(3,087 Views)
Hey Peter,
Coregen IP will be supported by the Kintex-7 FPGA.
However, in terms of using pre-programmed VHDL code made by Xilinx, it will be down to the specific code as to whether it works on the Kintex-7. The code won't necessarily be updated to work on the new chip.
Hope this helps!
Justin, Applications Engineer
(2,994 Views)
