Know the SubVI caller
I have a programme that is run with both "Labview " and "Teststand" . in this programme i have a SubVI in which i want to Know when it's called and what ils the VI caller . i do not want to open all the programme is it possible to Know that from the SubVI ?
Thank you .
(3,552 Views)
Use the "Call Chain" VI. You can find it in the Application Control palette.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,540 Views)
Hi , thank you
How to used properly ?
(3,537 Views)
Accepted by Emna20
Did you try using it? It returns an array of the VIs in the call chain.
From the help:
Requires: Base Development System
Returns the chain of callers from the current VI to the top-level VI. Element 0 of the call chain array contains the name of the lowest VI in the call chain. Subsequent elements are callers of the lower VIs in the call chain. The last element of the call chain array is the name of the top-level VI.
If you are using the current VI as a subVI, you can use this function to identify all the VIs that call the subVI.
If a LabVIEW project library owns a VI in the call chain, the function returns the qualified name of the VI, which includes the project library filename.
Mark Yedinak
LabVIEW Champion
(3,533 Views)
Do you know how to use LabVIEW Help to get "help" for any LabVIEW Function?  Do you know the "right-click-on-the-function-and-choose-Help" trick?
(3,478 Views)
When i use call chain it return only the name of the current SubVI . "the name of the SubVI in which i want to Know the callers "
i need explination for that ?
Thank you.
(3,465 Views)
When you only run the VI, the call chain will be empty except for the VI. You have to call your VI from another VI.
Do you want to know the callers at edit time and not at run time? You can find the callers by right-clicking on the VI and selecting Find->Callers. This will only list callers in the current project. The VI itself stores no information by which VI it is called.
(3,456 Views)
