Know vi parent
When I'm running a vi, I'd like to know the name of the vi from where I was called without using a command input. In other words, the name of my vi parent.
I tried to use the Callers' names propiety from "This vi" reference but I gave me all the vi's where my vi is included, not the vi from where i was called.
Thank you
(2,791 Views)
Try Application Control > Call Chain
(2,781 Views)
You should use Call Chain (Programming->Application Control->Call Chain). It will give you array with whole callers
hope it helps,
best regards,
Andrey.
(2,780 Views)
