Know when I am clicking in labview
I have a Slide With A+/A/A- and I want that second after I press/select A+/A- to change to A. The problem is that when I am pressing A+/A- for more than a second, it returns to A and inmediately change to A+/A-. So i want to put a case where it returns to A when I am not pressing the click of my mouse. I don't know if that is possible to know in Labview.
Message 1 of 8
(1,604 Views)
Hi lab,
Yes, it's possible!
Spoiler
You should use MouseUp/Down events, but don't forget about the MouseLeave event…
Message 2 of 8
(1,583 Views)
And how? Can you help me?
Message 3 of 8
(1,580 Views)
Hi, I didn't quite understand your question but I believe I can help you. Do you have the code where you are trying to perform this functionality?
Message 4 of 8
(1,566 Views)
Try this
https://tmesystems.net/
Message 5 of 8
(1,555 Views)
Hello, I can't attach all code because I don't want to share all my program. But the part that I want is this:
My start position of the slide if A
And I want that when I select A+, the slide stays in A+ for 1 second. After it, the slide must return to A. The problem is that if I am still clicking the point A+, after a second it will return to A and then instantly to A+. So that's why I want to put a case where it will move to A 1 second after I stop clicking A+. I hope i have explained myself.
Message 6 of 8
(1,549 Views)
With mouse event something like this:
on the other hand, there are different ways how to get things done.
Take a look into attachment. may be will be helpful as "getting started"
Message 7 of 8
(1,546 Views)
Accepted by topic author electronic_lab
Mouse Up event. you can also add Mouse leave event.
is it your idea?
Message 8 of 8
(1,537 Views)
