Kollmorgen AKD communication with Labview Ethernet/IP drivers
This vi will convert the modbus commands to a string.  You can have this in your code, but I chose to use it only to create the string that I send.
Message 11 of 60
(6,071 Views)
Any chance of getting that convert to string vi in Labview 2010 compatibility?
Message 12 of 60
(6,067 Views)
Wow, no thanks or Kudos but a request to convert?  Sure I would be glad to for a fellow member.
Message 13 of 60
(6,061 Views)
Sorry, MANY THANKS AND KUDOS!!! too focused on programming to be a decent human being I guess, my apologies!
Message 14 of 60
(6,059 Views)
I was just joking with you about the thanks and/or kudos.
I often can't help people very much since there are so many people on this forum smarter than me.  Since I get so much good info, I like to help when I can.
If you run into any more questions, don't hesitate to ask.  I was able to make my AKD drive work and it has been running fine in the customer plant.
Message 15 of 60
(6,043 Views)
The screen shot I made before of the write command is wrong, it is really a read.  Here is writing the command to home the servo.
Message 16 of 60
(6,045 Views)
nonecure, would you post a copy of your code? I may have to utilize this LAC as well, and this would help out so much!
Thanks!
Message 17 of 60
(5,931 Views)
Attached is my code for the Kollmorgen servo.  The servo engine vi runs in the background, and the servo request vi allows your app to send and receive commands to and from the engine.  The test manager vi is what I use to test this out standalone.  I am using the dynamic mapping feature of the drive, so I am reading/writing the 8192 area of the drive.  The dynamic map file shows the mapping I used.
-Doug
Message 18 of 60
(5,924 Views)
Sweet! Thanks. Kudos!
Message 19 of 60
(5,921 Views)
Hi Doug,
Do you have a copy of 'PostAlarm.vi' and 'G_System.vi' that you can post up to accompany your code.  These weren't included in the zip file.
Kind Regards,
Oli
Oli
LabVIEW Student Ambassador
National Instruments UK
Message 20 of 60
(5,901 Views)
