Kompatibility with DAQmx
i installed now the LabVIEW Version 2017,2018 and 2019 and none seems to be compatible with DAQmx 18.5.
The Problem is, that the DAQmx Version of my PXI System is 18.5 as well and i dont know, how i can update this Version to 18.6.
Best wishes,
Ache
(2,678 Views)
Try reinstalling the DAQmx Driver.
During installation, it might offer the option for e.g. "LabVIEW 2018 Support for DAQmx" or similar. Without that ticked, I think it won't appear in the palettes and menus, or be available within LabVIEW.
(2,670 Views)
i did not find the Option you wrote.
Now i reinstalled it and have the same Problem.
Thank you!
Best wishes
Ache
(2,656 Views)
Hallo Ache,
LV 2017 und LV 2018 sollten passen:
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Bei der Installierung vom DAQmx 18.5 hast du LabVIEW Support angekreuzt?
Welches Operation System hast du auf dem Rechner?
Was lässt du denken, dass es eine Inkompatibilität zwischen LV und DAQmx gibt? Genau welche Hardware wendest du an?
Treffendes Trouble Shooting Guide:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9xXSAS&l=en-US
Freundliche Grüße,
NI TSE
(2,629 Views)
i updated the Version on my PXI System and now it works!
Thank you!
Best wishes
Ache
(2,602 Views)
