LAB View crashes changing background colour
My LAB View runtime application (7.0) crashes sometimes without error message when changing the background colour of my frontpanel. My operating System is XPP.
(3,039 Views)
I have not found any reports of this behavior. When you re-launch LabVIEW does it offer to investigate the error? If so submit the error log so that R&D can look into the crash. If youa re not asked to investigate the error, select "Help>>Investigate Internal Error..." and see if there are any error logs. If there are submit them, and you can alos search on the file and line number to see if there are any KnowledegeBases about them.
Evan
(3,039 Views)
We have reproduced the crash with the development environment and with the runtime version (.EXE made with application builder).
Enclosed are 2 word files: one from development crash and one from runtime crash.
The runtime crash is from a computer with visual studion 2003 installed, so I made some visual studio debug snapshots.
At the development crash, there are no internal errors to investigate!
(3,039 Views)
Riegler,
From the attachments, am I correct in assuming it always happens in the same SubVI? Can you attach that so I can try to reproduce the crash, and can look at what may be causing it?
(3,039 Views)
