LABVIEW 2009 and lvanlys.dll
I'm relatively new to LABVIEW and I'm building an application with LABVIEW 2009.  The application works well on my PC.  However, the application is
intended to be ran on another machine.  I then tried two approaches.  First, I copied the executable file onto the second machine and second, I created
an installer file.  Both methods resulted in an error when the executable was ran on the second machine.  Here is the error:
"Missing external function lvanlys.dll Mean_Head.C in VI NI_AALBase.lvlib:Mean.vi".   I'm hoping anyone out there knows the solution to this.
Thanks!
Bobby C
(6,848 Views)
(6,826 Views)
I'm not sure that link is appropriate since it talks about LabVIEW 7.1 installer and windows NT.
For LabVIEW 8 or higher, make sure that the data folder is part of the install. Done correctly, there will be your application, the data folder, and in the data folder, lvanlys.dll.
(6,816 Views)
Hi guys,
I finally got it to work.  Somehow the fix was to download and install the latest drivers of my NI hardware (NI USB-6251).
Upon installing the latest drivers, I got my application to work.  Thanks again for your inputs!
Bobby
(6,771 Views)
