LABVIEW - MAKING A SIMPLE oscilloscope
I have a project to make an oscilloscope using labview.
Ive connected a function generator and sweep function generator to an xy graph.
I can play with it through frequency and amplitude.
The problem is: how do I make a control for TIME per Division and an another control for Voltage per division.
Help please!
Message 1 of 12
(32,616 Views)
I would probably use a knob control.  Change the representation to a I32.  Handle the changing of the values with an event structure.
Message 2 of 12
(32,610 Views)
Can you please explain to me how to do that coz Im a beginner (I know about the knob control) ?
I know that I need some calculations for it to work.
Message 3 of 12
(32,580 Views)
You need to manipulate the X and Y scaling minimum and maximum properties using the knobs. Quick example (i forgot the autoscaling property which should be turned off for both).
Message 4 of 12
(32,563 Views)
Hi
I want to design an oscilloscope with data acquisition card usb-6008 and I don't know how to connect daq and equipments. I need to design like above sample but  with daq. I don't have enough time. i need help.
sincerely
Message 5 of 12
(31,254 Views)
You are more likely to get good help if you ask specific questions.
Look at the DAQ examples. Some of those may be quite similar to an oscilloscope.
You can replace the function generator VI in the snippet posted by BillMe with the DAQ read VI. You might also need to couple the scale knobs to the amplitude range and timing for the DAQ device. That gets significantly more complicated becaues you will need to stop the DAQ task, reconfigure the task, and start it again.
Lynn
Message 6 of 12
(31,229 Views)
What have you done do far? Please attach the code and explain where you are stuck. Have you done any of the free tutorials? Have you done Help> Find Examples?
Message 7 of 12
(31,226 Views)
Can you please tell me what function that is with the key and ?!
Message 8 of 12
(29,276 Views)
Your question does not make any sense. The snippet above does not have any key. And, since it ids a snippet, you just have to save it to your hard drive and drag it to a block diagram. Then you can use Context Help.
Message 9 of 12
(29,264 Views)
I guess the wrench looks like a key, depending on how you look at it. 😄
Message 10 of 12
(29,259 Views)
