LABVIEW program for Riccati equation
Hi,I want to change the Riccati Equation from "-R^-1B^TPx" into "-R^-1B^T(P+delta rho)x". How I can make the VI in LABVIEW for this Riccati Equation or what should I add in LABVIEW VI for this Riccati equation.
(3,974 Views)
Are you just trying to implement the equation into labview? Can you post a picture of the equation? Im not sure whether or not there are cascading powers from what you have typed (use spaces and asterisks)
otherwise, is this how you want your equation
-(B^(T(P + δ ρ)) x)/R
or like this
-(B^T ((P + δ ρ) x))/R
(3,900 Views)
Yes, Plz Find an attachment which include the Riccati Equation which I am trying to implement the equation into labview.
Best Regards
(3,872 Views)
(3,869 Views)
Accepted by topic author tehseen172
to be honest this will work but there might be a more elegant solution (like putting everything over R instead of multiplying it at the start)
(3,848 Views)
You could also use Matlab script function in LabVIEW (Assuming youve got matlab installed) and run it through there with something like
R =
T =
B =
P =
Delta =
x =
u = -R^-1 * B^T * (P+Delta) * x ;
(3,843 Views)
