LABVIEW with Kpci
Hi all ,
I am using KPCI card 3100 and LABVIEW software ,, I have that card
inside my PC and a cable connected out in to a junction board ,, i
have a driver with that card called driverlinx it allow me to
communicate with LABVIEW .
The question is I want to insert a LED in the board and control it
using LABVIEW can u help me:)
(4,226 Views)
It looks to me like the KPCI-3100 refers to a series of Keithley PCI cards.  You should find out which one you have (KPCI-3100 Series boards include the KPCI-3101, 3102, 3103, 3104, 3110...).
Here is a link to the KPCI-3101
http://www.keithley.nl/products/dataacqmodules/pciboards?mn=KPCI-3101
Then I would use one of the digital IO line to control your LED.  You will need to find out how your break out box connect to the PCI card.
Besides the driverlinx software I think you need to get some labview drivers that make use of the driverlinx.  The following link is to a buch of sofware for the KPCI-3101.  At the bottom are driver software.  You indicate you already have DriverLINX.  If you don't have the LabVIEW VI for the DriverLINX already, download from here.
There are also a buch of example programs on this page that might be helpfull.  There is a good selection written in labview.
Hope this helps
(4,215 Views)
(4,213 Views)
paulmw wrote:
> Forgot to paste the software link, sorry
> <a href="http://www.keithley.nl/products/dataacqmodules/pciboards/?path=KPCI-3101/Downloads#5" target="_blank">http://www.keithley.nl/products/dataacqmodules/pciboards/?path=KPCI-3101/Downloads#5</a>
> &nbsp;
I have seen that links b4 , but I didnot help me alot , I built my
circuit " its so smal one only for testing the communication between
the KPCI and LABVIEW ,, Concerning that I installed all required
software now I have an icon in the LABVIEW that indicated KPCI ..
My question now , where should I place that icon (kpci) in my circuit
in LABVIEW???
(4,187 Views)
Since I don't have access to the 3rd party board and this is not a driver that is supported by NI, so I would suggest that you look at those example programs in the link above.  It seems that many of them use the driver you are working with and you should be able to modify one of the examples to suit your needs.
Have a fabulous weekend!
Janell R. | Applications Engineer
(4,170 Views)
