LAN controled Relayboard
Hi
I try to use a Numato LAN Relayboard (Telnet). But for some reason I can't connect to the board using TCP. The default username and password are "admin". And it work just fine, when I use the web interface to the board.
But when I try to make a connection with Labview, I get the error "Access denied".
What do I do wrong?
(1,442 Views)
I don't use telnet the often, but it seems like you have to pretend to be a telnet client. Sending the raw strings over TCP is most certainly not going to work. I vaguely remember other forums users reporting success by remote-controlling a third-party telnet client via LabVIEW, maybe that can point you in the right direction.
Alternatively, since there seems to be a fully featured web interface that is not HTTPS-encrypted, you could reverse-engineer that interface. You would start by using your browser to connect to the Relay Module and open the development console on the browser (e.g. Ctrl-Shift-I on Firefox). Check the network traffic while submitting the login form. Your browser will tell you the raw data it sent to the board. Use that raw data in your VI and see if that gets you moving forward.
Edit: I assumed that this is the manual for your board: https://numato.com/docs/16-channel-ethernet-relay-module/
(1,398 Views)
I actually like the Numato board.  I used their 64 relay board on a couple of projects with a lot of success.
Now for the weird part with this board: It is following the telnet standard to the extreme.  You see those weird characters at the start of the first read?  Those are option codes.  If you don't respond to those, the board will reject anything you tell it.  I spent more time than I care to admit digging through the Telnet standard to work through this.  In the end, here is the code that I made for reading from a Telnet device.  The main is just reading the string.  Then the subVI checks for option codes and then just affirms whatever options were sent by the device.
(1,386 Views)
