LAN detection
HI all,
i have  aproblem with an Ethernet Interface Module.
the module is getting supply voltage from a common powersuppy (24v).
By emergency stop, the module is switched off and the LAN is disconnected. but the vi is still running.
Is there any funtion to detect a LAN connection (if the module is switched on again)?
or
is it enough to use the 'TCP Open connection' to  wait till a connection is established?
any help will be appreciated.
RENN
Kudos always welcome for helpful posts 🙂
(3,725 Views)
Accepted by topic author RENN
You can try to use ping. However, as I noted in this message, ping operates differently based on the OS. In that message I showed simply using TCP Open Connection.
(3,694 Views)
thanks  a lot smercurio fc... it works!
(3,659 Views)
