LCD image reading
Spoiler
Hello dear
have you got succeed in your project?
i am also working with same projects.
if you could help me.
asif
Message 11 of 14
(1,157 Views)
Hi.
I remember than I success, but that was long time ago and with previous JOB, so I don't have the code anymore.
just follow the examples than I received here..
Message 12 of 14
(1,144 Views)
oh. can you guide me any more? i am stuck just following one youtube example.
 but not got success so far.
thanks,
asif
Message 13 of 14
(1,121 Views)
Basically, I use the samples listed here.
but you need to have installed and activated the 'VISION' module, it is not free.
if you have it installed, maybe I can help you.
I'm sure you can find a better solution for this, now the OCR systems are accurate compared with 7 years ago.
the VI's than I make "work", was not totally accurate, even for a simple 8.8.8.8. display,  I can not imagine if you need to read CAPS, lower case letters, numbers, special characters etc.
good luck!
Message 14 of 14
(1,101 Views)
