LCM divider rest
hey everybody,
I would like to divide one array by another array and deal with the REST of the division of each element.
Unfortunatly I can't find a function that provides (only) the rest of a division.
I need this to build an application to calculate the lowest common multiple. Does anyone already wrote such a program? It would be very helpful for my if I could use it.
Thanks Claudia
(3,848 Views)
By rest, do you mean remainder? If so, then there's the function Quotient & Remainder on the Numeric palette. You can wire arrays to the x and y inputs and get an array output of all remainders.
(3,850 Views)
Hey Dennis,
you were right. Finaly I used this *.vi
Thanks for your fast and good reply
Claudia
(3,827 Views)
It is something different that I'm looking for. With "rest" I mean like:
7/3=2.333333 (so the rest is 0.33333)
or
9/4=2.25 (rest=0.25)
I'm interested in the values after the comma and not in the modulus or remainder.
I'm very appreciate about every help
Claudia
(3,804 Views)
How about this (attached)?
--John
(3,800 Views)
Where can I find this function?
(3,433 Views)
