LDF KIT Starter
Hello guys, I'm looking for a method to install the LDF Starter Kit for LIN, but I can't find anything.
I found the attached link, http://www.ni.com/download/ldf-starter-kit-for-lin-1.0.1/665/en/  but it doesn't work.
I am working with the LIN protocol version 2.1. Thank you for your help.
(1,292 Views)
LDF Starter Kit for LIN is very old and has been obsoleted.
What hardware are you using? USB-8506 or USB-8476?
https://tmesystems.net/
(1,261 Views)
Thaks for the answer,
I am using TRC-8546, CABLE TRANSCEIVER,
(1,256 Views)
Accepted by topic author sasquatchd
LDF Starter Kit for LIN is for the legacy USB-8476.
TRC--8546 uses NI-XNET. After you installed the NI-XNET driver, you can load and browse LDF files using NI-XNET Database Editor
(1,246 Views)
