LED Array
Im new at using labView and i have a problem.
Im trying to create a VI that searches the values of an input array of numbers of a specified value. If the specified value is found in the array the VI shpuld indicate that by turning on an LED and indicating the corresponding index of the array.
I would really appreciate if someone could help me with my issue.
Message 1 of 10
(5,625 Views)
Sounds like homework.  Show us your attempt and we'll help you work through it...  Smiley Happy
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 10
(5,617 Views)
This is what i have, but i dont think it rigth.
Message 3 of 10
(5,574 Views)
Nope.  Not right.  You are just determining whether the value you are looking for is equal to the length of your array.
Try "Search 1D Array".
Message 4 of 10
(5,560 Views)
You're not using Search 1D Array Function, rather you're using Array Size function.
Try out attached code, Index of Element output of Search 1D Array Function is -1 if the element is not found in the input array.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 5 of 10
(5,556 Views)
It's generally better to guide them to the solution rather than giving them the answer to their homework.Smiley Wink
Message 6 of 10
(5,553 Views)
I got it...!! Smiley Happy
Message 7 of 10
(5,538 Views)
okay i found the search 1D array. Do i  just add a Equal to function to get to work?
Message 8 of 10
(5,526 Views)
Yes you need an equal function.  Actually, you could also use <0 function to determine if the element was found or not.
If you read the help for Search 1D Array, you'll see that a value of -1 is returned when the element is not found.
Message 9 of 10
(5,496 Views)
Thanks for the help i got the VI to work.
Message 10 of 10
(5,465 Views)
