LED INDICATION
    In my attached VI you can see that my numerical values are converting to string of 1byte.I need some instructions one how to make LED ON on zeros and LED OFF on ones.
(4,004 Views)
could look into number to boolean array (its in programming ->numeric -> conversion) then using a NOT gate to invert it. Hope it get you going in the right direction
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,994 Views)
A couple of points:
  • You should not be using a DBL if you are dealing with bytes. Make the numeric control a U8. Then you can use the function mentioned by Akiel without needing to convert to a string.
  • Don't create a Greedy Loop .
(3,991 Views)
Thanks for promt reply.And sorry for posting such a simple question.
Here is the VI.
(3,967 Views)
You still made a Greedy Loop.
Was there something else you needed with that VI? It appears to do what you want, based on your original question.
(3,947 Views)
Greedy Loop?I removed the while loop.
OK?
(3,938 Views)
So you do not need a loop?. A loop without delay is a Greedy loop simply you could have used a delay function.
(3,932 Views)
