LED Value Change ?
Hi .. it's me again 🙂
I currently have two LEDs (well, boolean values). Now I'd like to call an event when anyone of those changes. They cannot be changed by the user, but only programmatically.
I added the Value Changed Event to those two but no event is fired when I anyone of them gets lit ...
am I doing something wrong ?
(3,115 Views)
In the first place, you should only change the value using a property node, through the Value(Signaling) property
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,111 Views)
thank you .. I'll try this on monday 🙂
(3,092 Views)
Thank you .. worked perfectly 🙂
(3,069 Views)
