LED command timed loop counter
hi!
I made this program who does the following sequence:
1. a switch for on and off
2. it will turn on the my LED then turn off after X seconds.
This is attached to my digital output so i can that my attached voltmeter reads voltage
It worked fine but i noticed it only does two iterations so i do not know where i made mistake
Help!
(3,882 Views)
Hi camr,
any error messages?
How did you configure your switch? Does it use switching or latching mechanical behaviour?
What's the point of ORing with FALSE? 😉
(3,863 Views)
No error message.
mechanical switch: latched when released
What's the point of ORing with FALSE? - my bad, i belatedly saw that redundance.
(3,858 Views)
Hi camr,
so your switch is reset to FALSE as soon as it gets read. And you wonder why your loop doens't count seconds anymore?
Did you try to debug your VI using basic debugging tools like highlighting? What are the inputs to the AND function in each iteration?
(3,854 Views)
@GerdW wrote:
Hi camr,
it does count.
it works well
but the iterations only goes twice.
(3,852 Views)
Hi camr,
then check your STOP condition. When the loop only iterates twice it seems to be stopped unexpectedly. (That's why I asked for error messages…)
(3,849 Views)
