LED indicator --
So I have parsing data from serial port and every new frame basically has a value for a particular sensor.
I just want to have an indicator LED next to active sensor data i.e if current packet has frame for Temp then temp led shoudl light up next to parsed value...
This is helps in knowing which value is currently being updated . Is there a way??
(2,915 Views)
(2,903 Views)
