LED,s glow via labview serial communication
hello
i want to make a gui in which i glow LED,s via boolean switches and i want to serially communicate with rs232 and 8051 .4 leds are at p 2.0 p2.1 p2.2 and p2.3 when i presses button 1 led at p2.1 glows than similarly with other button as well .what does string means and why we convert into it ...8-bit data transmit serially to rs232 and comes with low and high logic.how can i come up with 4 different but logic high signals to microcontroller  at different pins so by doing setb command i can glost the required port which i want.please assist with VI code also i have limited knowledge of hardware as well so wat hardware will be used???
thanks for assistance
(2,688 Views)
Your description is not clear at all. Can you attach an image or simple VI front panel?
(2,668 Views)
