LED
Hi everyone, i'm very new to Labview. I was trying to create 10 running LED. something like a lift button. Example if the the user settle a number 4, the LED shall light from LED 1 then off, then on LED 2, then off and continue until LED 4 and stop. How can I create?
Please kindly teach me.
Message 1 of 28
(5,749 Views)
For some reason your username gave me an association with some fine 80's television.  Here is an example using several LEDs.  The key elements are using number to Boolean Array to get the value for an array of LEDs.  The number you use is 2^N where N is the number of the LED you want to light.
Example below.
Message 2 of 28
(5,733 Views)
Here's one simple implementation for 5 LED
Andy Chang
Message 3 of 28
(5,724 Views)
Hehehe...
Thank for your kind respond.
Anyway I'm using version Labview 8.6. do u think you could save it in V8.6?
Message 4 of 28
(5,724 Views)
Accepted by topic author niteflame123
here in 8.6
Andy Chang
Message 5 of 28
(5,720 Views)
Also in 8.6
Message 6 of 28
(5,714 Views)
Thank you so much, Andy C and Darin.K 😃
Message 7 of 28
(5,709 Views)
Hi Darin, as i'm really new to Labview,I was wondering how can I let the light LED stop at the number I settled.
Message 8 of 28
(5,709 Views)
Your original problem is much simpler, I was trying to give you a bit more to chew on since you asked to be taught something.  Here is all you need to do.
Message 9 of 28
(5,670 Views)
Thank for your replied.
I was thinking that the first circuit that you showed, how can i used the reversed array for the 2nd circuit you used? Because i was thinking of when the LED stop at No 4 LED, can it reverse back to LED 2 if I re-indicate the selection?
Message 10 of 28
(5,657 Views)
