Hello every one:
I am trying to generate chirp signal and receiving it using USRP(2932) , the transmit port (TX1) of the USRP is connected to the receiving port (RX2) of the same USRP through RF cable .
How I ensure that the signal is received correctly , what is the shape of the received signal and its properties ?
the transmitted signal is attached in the figure below
