LIFA 2 or more analog inputs.
Hello!
I want to make an interface in LabView using Arduino. I am using LIFA but i heard that is no longer supported since 2014 or something like that and LINX now is used.
If a test a single analog sensor (LM35-for temperature) is all good. When i add another one (in my case, pulse sensor) the interface is showing me the results but not the way i wanted. The temperature is constant, real but jumps 20 degrees then return to the real value, all real quickly. In my project, which is in 2 months i would like to have another one. (3 analog sensors). Is it possible to work, in the end with LIFA? And if not LIFA, with LINX can i read all 3 sensors in real time?
Thank you!
(2,213 Views)
Hello lucianpetcu
Have you tried any code? If so, can you attach it as a picture or as a vi?
Have you posted this question on the LINX forum? They may be more familiar with this add on.
https://www.labviewmakerhub.com/forums/
(2,166 Views)
