LIFA
HELLO
I AM MAKING A  FIRE ALARM USING LABVIEW.
I WANT TO MAKE ASYSTEM WHERE WHERE THE DANGER LED GLOWS WHEN THE LDR READING GOES PAST A CERTAIN PRE DEFINED VALUE
I AM USING A GREATER THAN FUNCTION BUT LABVIEW SAYS THAT THERE IS A PROBLEM WITH THE CONNECTION
REQUEST ONE AND ALL FOR HELP
FUTHER HOW CAN I ADD A DIALOG BOX TO ACKNOWLEDGE THE DANGER LED
REGARDS
JALASHWA
Message 1 of 25
(6,552 Views)
HELLO,
You have wired two incompatible data types to your >= function.  You are comparing an errror cluster to a value so it won't compile; you need to wire the Light Intensity instead.
More information about error cluster here.
If you are new to LabVIEW I would recommend spending some time leaning the basics. It will save you much time in the long run
LabVIEW Training: Learn LabVIEW in Three or Six Hours
Lewis Gear CLA
LabVIEW UAV
Message 2 of 25
(6,549 Views)
HELLO
THANKS FOR NOTIFYING ABOUT THE ERROR
SINCE I AM NEW TO LABVIEW WOULD REQUEST YOU TO HELP ME COMPLETE THE VI
WITH WARM REGARDS
JALASHWA
Message 3 of 25
(6,528 Views)
First.  Please check your CAPS LOCK key.  It seems to be stuck on.
Second, Lewis's e-mail is pretty clear on what you need to fix.  You can't compare whether and error cluster is >=0.  If you wire in the light intensity wire instead of the error wire, you won't have a broken wiring connection.
Message 4 of 25
(6,513 Views)
Caps Lock is cruise control for cool.
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
Message 5 of 25
(6,502 Views)
thanks a lot everybody the VI is running smoothly was wondering to add an acknowledgement button for the LED ie. the LED sops glowing when the button is pressed would appreciate if someone can help me with that with warm regards Jalashwa
Message 6 of 25
(6,481 Views)
HELLO,
You could wire your button to a Select Function, along with a Boolean constant and the result of your comparison function.
You could have answered this yourself if you had looked at the training material i suggested...
Lewis Gear CLA
LabVIEW UAV
Message 7 of 25
(6,460 Views)
hello
i thank all of you to will complete my vi
i was thinking of adding a  dialog box to warn the operator during a danger situation
need some vi as i cant run the vi
i am attaching the vi for your reference
with warm regards
jalashwa
Message 8 of 25
(6,441 Views)
hello i thank everybody for helping me complete my vi i was wondering if it possible to add an one button dialog box to warn the operator about any danger situation i cant seem to find the correct location to place th output wire of the dialog box will appreciate some for help regarding thge above issue i am attaching the vi for your reference with warm regards jalashwa
Message 9 of 25
(6,437 Views)
Message 10 of 25
(6,431 Views)
