LIN Master Send Full Frame And Receive.vi issue
Hi everyone,
I have one question with the demo program"LIN Master send full frame and receive.vi", I try use this demo program to download parameters to the electronic card by usb-8476 LIN module, I have setup the interface as LIN0, the bandrate as 19200,(both are correct setting), the problem is when I send out the arbitrationID(3C) and the data, it should be response back rbitrationID(3D) and data, but I don't see it response, I don't know where is my problem?
I have checked the wiring cable is correct collect.
If somebody can help me find the problem?
Thank you so much!
(2,321 Views)
have you tried different values for LIN0 or arbitration ID?
Is there any other example available for your module? Have you checked is it working?
(2,249 Views)
I have found the problem.  now it's working.  Thank you!
(2,230 Views)
Explain what the problem was so that others in the future with the same problem finding this thread might benefit!
(2,214 Views)
Can you tell me how to solve this problem
(2,054 Views)
