LIN application
 Hello   DirkW  I dont   use
 Vector labVIEW driver  for  my  application.
I  made  a program  in labview  use    VXLAPI.DLL
the  function  XLRECEIVE   in  LIN APPLICATION   not possible look the data  .
The   program  in VISUALC++  use  VXLAPI.DLL the same function   XLRECEIVE   it is  possible  look the data .
I hope of being to explain .
Saluti      Battista
(3,057 Views)
you are using a Vector XL Driver Library so if you have some problems with a specific function I think this is more a question for the Vector Informatik support.
About LabView you can find some usefull tips about how calling external API with examples and troubleshooting informations in the manual at the link below:
https://www.ni.com/docs/en-US/bundle/370109b/resource/370109b.pdf
Saluti
Clara
(3,020 Views)
