LIN protocol
I am using Labview 7.1 as SW to send LIN command(Identifier+databytes) to an Atmega board which generate the protocol, does anybody know how to calculate in LV the checksum for the identifier and databyte(see the comment below)?
The checksum is the inverted modulo-256 sum
over all data bytes(Identifier+databytes). The sum is calculated by an 'add with carry' operation with the carry bit of
every addition being added to the LSB of the resulting sum.
(4,377 Views)
(4,361 Views)
Hello unclebump,
Thanks for the reply but i am not looking for any LIN interface i am just looking for a code in Labview which can calculate the checksum of the identifier an all databytes from the LIN protocole, it is in fact an inverted  modulo-256, in assembler we do it as an add with carry.
(4,351 Views)
See attached VI.
(4,345 Views)
HI JB,
I have used your via in the following way (see attached pic).
Thanks again
(4,279 Views)
