LINEAR MAPPING OF INPUT
Hi all,
                a basic problem about linear mapping of inputs insome defined range. problem is explained in the attached image. Any help would be appreciated.
(4,422 Views)
We don't do your homework here.
(4,409 Views)
Hi smercurio,
                         I didnt mean that somebody work out my problem. All i asked if any body have a hint would help me. I had good intention of learning something here thats it.
Thanks a million for your help...
(4,389 Views)
Think of it this way.
You have a range of 0->100 for pressure and -5->5 for the voltage.
Looking at the sizes of the range you have 100atm increase for a 10V increase. (as per the question)
It's linear so the you'd have 50atm after an increase of 5V (from -5) (as per the question).
Based on this, (and ignoring labview completely), how would you convert a voltage to a pressure?
Once you determine this, converting to labview will be simple.
(4,383 Views)
As the previous poster says, ignore LabVIEW for a moment. On a piece of graph paper draw the two ranges, the pressure on one axis, the voltages on another. Now use the basic algebraic formula for finding a point on one axis if you know the corresponding value on the other.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,371 Views)
Hello all,
                     Thank you for all of your help. I have solved the problem. I just posted it because for a while i was stuck with this. I took labview wiki help.
(4,353 Views)
