LINX 3.0 on the Raspberry Pi 2, 3 and 4 running Raspbian Buster
Thank you, I followed all these threads but still cannot connect Pi4 4 Gb to LINX in Labview 2018.
Unable to connect to the target.
VNC, RDP and putty working correctly on that IP address.
Message 31 of 33
(925 Views)
Hola esto se debe almenos en mi caso por que la version raspi no puede conectarse al repositorio se soluciona agregando la parte de [trusted==yes]
Message 32 of 33
(393 Views)
I can install the software from Makerhub, add the Raspberry disposition to my project and connect, all good until trying to run the simulation, do you know why?
Message 33 of 33
(370 Views)
