LINX- custom command
I created my custom command for LINX arduino interface.MY doubt is coding using  predefined command like Analog read ,digital read ....needs to upload into ARDUINO.In custom command Code is generated in Arduino IDE and then uploaded into Arduino.My doubt is if i use both custom command and Predefined command in same coding whats the procedure to upload code into arduino?
                                               THANK YOU
(3,983 Views)
This question would probably get a better response on the LabVIEW Makerhub  LINX forum.
=== Engineer Ambiguously ===
(3,923 Views)
