LINX target configuration fails to update on RPI4 with Community edition 2020
I am trying to connect my Pi4 to the community edition 2020 (also tried 2022 q3 version), it connects  but then when trying to install the available version it fails (a message failed to install quickly pops up and then disappears on the bottom border) and the installed version remains blank.
I am pretty much a noob at this and trying to learn so any help would be much appreciated.
(1,218 Views)
Hi SuSu74,
There is an article about Using Raspberry Pi with LabVIEW - NI. Try to use this article to correct your issue.
Here is another one in case if you will have an error with this connection look this article as well.
Regards)
(1,140 Views)
