Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
LISTBOX with checkbox
Thijs Boeree
Member
10-03-2001
07:35 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi, does anyone knows how to make a listbox with text + a checkbox
(boolean), so that it is possible to check a specific item in the listbox?
Thijs Boeree
0
Kudos
Message
1
of 3
(3,157 Views)
Reply
Re: LISTBOX with checkbox
Gorka Larrea
Active Participant
10-03-2001
07:56 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Well, i've managed a workaround, but it only works in one direction (check the boxes >> selected in listbox) if you want it to work in the other (check the listbox >>boxes selected) you must use another local variable.
Hope this helps you
ListboxCheck.llb 20 KB
0
Kudos
Message
2
of 3
(3,157 Views)
Reply
Lab Viewer
Active Participant
10-03-2001
08:02 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Take a look in lv foder\examples\general\listbox.llb ... it seems to be what you are looking for.
hope this helps
0
Kudos
Message
3
of 3
(3,157 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
