LLB for LV8.61 to work with sample VI PXI-4351
I use LV8.61 and installed driver for PXI-4351, NI435X v252.
While I try to use sample vi came with v252 (Measure Thermocouple (with Accessory).vi), I get error for
missing LLB, vilib\DAQ\MISC.LLB\Get DAQ Device Information.vi
Indeed I can not see \LabVIEW8.6\vi.lib\DAQ folder.  How I get this LLB and needed update?
Message 1 of 13
(3,730 Views)
You need to install the obsolete traditional DAQ driver. Click the support link and do a search.
Message 2 of 13
(3,718 Views)
Thanks for reply.  However, Traditional NI-DAQ 7.4.4 is already installed.
The product came with driver v2.5.
Message 3 of 13
(3,710 Views)
Unless you are using windows 7, it should be there. Is there anything in that folder?
Message 4 of 13
(3,706 Views)
Actually, there is no "DAQ" folder at all.
The os is XP sp3.
Message 5 of 13
(3,685 Views)
Let me correct myself, there is no "DAQ" folder under "vilib", but there is "DAQmx" folder.
Message 6 of 13
(3,684 Views)
Sorry for my misunderstanding.  Traditional DAQ was not installed.
In my control pannel, installed software list, within NI software, it showed TDAQ744 installed.
However, it was not.  I installed TDAQ744 and sample vi worked.
Thanks for help.
Message 7 of 13
(3,670 Views)
You should mark Dennis' message as the solution to your problem rather than your own thank you message.  First you will need to unmark your message as the solution by going to the Options menu to the upper right of your message.
Message 8 of 13
(3,666 Views)
I can not fine "unmark" in upper right option tag list.
I reported to moderator that I like to unmark.
Message 9 of 13
(3,651 Views)
Your message.  The one you marked as a solution highlighted in green.  There is the options menu to the upper right of that.  In the green bar.
Message 10 of 13
(3,645 Views)
