LMS filter code
Hey there!
I am having trouble implementing a LMS filter I have downloaded from the forum. I have to submit this project for grading soon and I cannot figure out the reason why the output filtered signal is a flatline. I will attach the VIs.
Thank you in advance!
(3,130 Views)
Hey there guys!
I am having the same problem. The output signal after having been filtered with the LMS filter is a flatline.
Can anyone help me with that?
Thanks!
(3,130 Views)
Hey there Brandon!
I am having the same problem. The output filtered signal is a flatline. Could you please help me?
Thank you!
(3,127 Views)
Hi Bixy,
please don't ask the same question in 3 different (and old) threads.
Create you own thread and stick with it!
On your question:
The output of that LMS filter is "flat" because you are using it in a wrong way!
Do you understand, how that subVI works? Do you understand which data to wire to its several inputs and how to use all of its outputs?
(3,117 Views)
