LPVOID equivalent in LabView ?
One of the parameters that needs to be passed into an MFC DLL is LPVOID.
What is the LabView equivalent Data Type ?
DOK
(3,353 Views)
There isn't one, though you can consider that a pointer is just an integer. That said, in cases like this the best solution is to use a wrapper DLL to interface between LabVIEW and the "funky" DLL. Is the void pointer a return value or an argument? This older thread indicates that an array was used, but the situation may be different in your case.
(3,329 Views)
