LStrHandle C++ String conversion
Hi, I am wiring a cluster that holds a string into a Call External Library Node and following the "Adapt to Type" article and "Calling External Code in LabVIEW" manual, I have created a .cpp file with this code in it:
typedef struct {
double Numeric;
double Numeric2;
LStrHandle String;
} TD1;
However, I am using a function that requires a C++ string to be passed into it and it returns a C++ string that needs to be assigned to LStrHandle String. Is it possible to convert the LStrHandle format into a C++ string and vice versa? I found something regarding the LStrPrintf functions, but I'm fairly new with programming and I did not follow it very well. Thank you in advance.
(7,022 Views)
typedef struct {
double Numeric;
double Numeric2;
LStrHandle String;
} TD1;
I'm not familiar enough with C++ to tell you exactly what to do. I specially find the C++ string operators quite hard to comprehend. But a LabVIEW string handle is basically as follows:
typedef struct
int32 len;
uInt8 buf[0];
} **LStrHandle;
The len integer tells you how many characters are there while the buf member points to the actual string but without a NULL termination character.
So in C you could do something like this:
MgErr MyFunction(LStrHandle handle)
char *string = malloc(LStrLen(*handle) + 1);
memcpy(string, LStrBuf(*handle), LStrLen(*handle));
string[LStrLen(*handle)] = 0;
use your string in whatever way you like. Then copy back a C string into the LabVIEW string.
Either use LStrPrintf or doing it yourself:
int32 len = strlen(string);
MgErr err = NumericArrayResize(uB, 1, &handle, len);
if (err) return err;
memcpy(LStrBuf(*handle), string, len);
LStrLen(*handle) = len;
You will need to adapt this to C++ strings somehow.
Rolf Kalbermatter
Message Edited by rolfk on 06-20-2005 05:15 PM
Rolf Kalbermatter  My Blog
(7,003 Views)
typedef struct {
double Numeric;
double Numeric2;
LStrHandle String;
} TD1;
I just had a look at my C++ textbook and it shouldn't be terribly difficult to do it for C++ as well:
MgErr err;
string s(LStrBuf(*handle), 0, LStrLen(*handle));
Now you can pass s as a C++ string.
Then copy back a C++ string into the LabVIEW string.
err = NumericArrayResize(uB, 1, &handle, s.length);
memcpy(LStrBuf(*handle), s.cstr, s.length);
LStrLen(*handle) = s.length;
return noErr;
(6,996 Views)
Hi rolfk, that helps me out a great deal. It was much easier to understand than most explanations I've gotten. However, the line that reads:
is giving me a compile error. It says that it cannot convert parameter 1 from 'uChar*__w64' to 'const std::basic_string<_Elem,_Traits,_Ax>::_Myt'. I'm guessing the LStrBuf function is not returning the proper data type(which appears to be a C++ string) to be passed into the constructor there. I'm unfamiliar with that function so I'm not sure how to proceed to fix this. How might I proceed to do this? Again, thank you in advance for the advice.
(6,990 Views)
Well LStrBuf is only a macro accessing the string buffer in the handle but it is a little bit complicated so that the C++ compiler might get into trouble here seeing a type he doesn't know to interpret as C string.
Maybe you could try to use something like
s((*handle)->str, 0, LStrLen(*handle));
instead, or you might even have to cast the buffer explicitedly to a (char *) to make it work such as:
s((char *)LStrBuf(*handle), 0, LStrLen(*handle));
s((char *)(*handle)->str, 0, LStrLen(*handle));
Rolf Kalbermatter
(6,977 Views)
