LStrPrintf signedness warning in CIN app
So is there a way to to send "type anything you want" as unsigned char data instead of char?
I know U can build a struct, and force data to be signed or unsigned, but for a string inside quotes in something like sprintf and similar is there a way toforce it?
Message 11 of 13
(653 Views)
Yes find the compiler flag that tells the compiler to use unsigned character strings as default. Visual C uses for this /J which is best used when compiling code to link with LabVIEW headers.
Or admittedly considered very ugly by most, typecast the string constant to an unsigned character string specifically
(CStr)"This is any string treated as unsigned char array!"
If the typecast is uglier than the warning message you have to decide yourself. I personally think C compilers complaining about this with default warning level, are a bit over the top.
Message Edited by rolfk on 11-24-2009 10:39 PM
Rolf Kalbermatter  My Blog
Message 12 of 13
(652 Views)
Are you using .cpp or .c?
I had problem with .cpp before with LStrPrintf.  Change to .c solve all the problem.
George Zou
George Zou
Message 13 of 13
(633 Views)
